Re: 350 Utility Hyd. Breather
Posted by Don Benson on July 04, 2007 at 10:49:46 from (71.98.210.160):
In Reply to: Re: 350 Utility Hyd. Breather posted by C.C. Schlossnagel on July 03, 2007 at 17:54:32:
I check it running with the piston extended, better to be a little over as it will go out the breather, if you run them dry they can be a pain. another way to check for leaks (internal leaks) is to fill the cylinder (fully extend it ) take the weight off with a jack and plug the hoses with 1/2 plugs (or whatever size the hoses are from the control valve)remove the jack and let it set for a while see if the cylender goes down this will isolate the cylender from the valve. if it goes down it needs rebuild or replace, if it holds put some weight on it and check again. repost if you need more help!!!!
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
