Re: Mc-D 10-20 Tractor Drives
Posted by Bobcat on July 04, 2007 at 19:19:35 from (71.7.57.128):
In Reply to: Mc-D 10-20 Tractor Drives posted by Big Red Man on July 04, 2007 at 18:51:04:
Cutting the center part out of a set of tractor tires works well for parades. I have done a couple tractors that way and found that a chain saw is about the easiest method. But be carefull it is quite dangerous! Do a little at a time and be prepared for a mess to clean up and a blade to sharpen. Try to get them as tight on the rim as you can while useing carriage bolts to hold.
As for making a 10-20 fast enough for tractor rides good luck. The brake band would not be very good at stopping if you do rig up a way for speed! There was a high speed option for W-30's but I think the transmission and brake was alot different. I hope this helps You!
