Re: Unknown,weird bolt
Posted by JohnG(TX) on July 05, 2007 at 07:24:45 from (216.136.20.34):
In Reply to: Unknown,weird bolt posted by SuperA-Tx on July 03, 2007 at 18:25:25:
This bolt and nut were used on the early Farmalls and others to hold the middlebuster bottoms on to the plow arms. I found many of them on my grandfather's farm, many still in the buster bottoms where they go. These buster bottoms are the ones with the cast iron shoe and three steel plates. They fit into the cast iron receiver, that is bolted to the steel plow arm. You use a hammer to tighten the nut.
