Re: Mag to electronic ignition.
Posted by John T on July 05, 2007 at 08:51:55 from (66.244.83.147):
In Reply to: Re: Mag to electronic ignition. posted by El Toro on July 05, 2007 at 07:33:17:
Hal, Sometime I gotta get one of you IHC guys to educate me on those IHC mags (I need to get one n take it apart n study on it lol). Heres my question, You and I or Jim discussed this a while back and you or him even posted a page from a manual buttttttt I forgot it grrrrrrrrrr. On mags with the spring wind n trip impulse assembly, before the spring winds n the impulse trips, it looks to me like the rotor tip position would be BEFORE where it would be when she trips n fires IS THAT RIGHT OR NOT????????? If it issssssss right?????? How about if hes setting up a distributor timing from scratch we should advise him to get the No 1 piston at TDC on its Compression Power Stroke and thennnnnnnnn install the distributor so the rotor tip is lined up with the internal cap tower that leads to that No 1 cylinder?????????? Of course, if the mag dont work like I was guessing, I see n understand your post as the easy simplest way to install the distributor so its in basic time. Henry, Once you have the distributor n switch as Hal mentioned (I would feed battery voltage to the ignition switches BAT input terminal from the ammeters load side terminal and its IGN output down to the coil, of course) you need a coil. That would be a 6 volt coil if its a 6 volt tractor, while if its a 12 volt tractor you can use EITHER a full true 12 volt coil or a 6 volt coil plus a series ballast resistor. John T NOT an IHC Mag guy but like to learn
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
