Re: i'm stumped 2
Posted by Janicholson on July 05, 2007 at 10:41:37 from (199.17.6.136):
In Reply to: i'm stumped 2 posted by james in mo on July 05, 2007 at 09:53:43:
Start it and run it for as long as it takes to not start again.
Pull a plug wire off and put a good (used is OK) sparkplug into the loose end. Ground the body of the plug to the engine, and have someone crank it (neutral etc.) If no spark, or weak and yellow, I would replace the condenser, then points, then a different 6V coil. (in that order). If the spark is good, The Carb may need a going through to be sure it is not causing flooding. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
