Re: i'm stumped 2
Posted by georgeky on July 05, 2007 at 11:06:55 from (152.163.100.197):
In Reply to: i'm stumped 2 posted by james in mo on July 05, 2007 at 09:53:43:
Try running a hot wire from battery to the coil and see if it will start then. You won't need the switch on for this. It will not tell what the real problem is, but will eliminate some of the possible causes. If it starts and runs you can mark the points,coil and condensor off the suspect list. Then look at some of your wiring. Could even be a short in the starter, swith or who knows what.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
