Re: oil galley plugs in 123 engine?
Posted by homard on July 05, 2007 at 13:00:23 from (143.69.70.148):
In Reply to: Re: oil galley plugs in 123 engine? posted by BIG RED 1 on July 05, 2007 at 12:15:48:
I have no experience with JP Tractor but, right now it does not sound like a pump issue. Assuming the obvious (correct weight oil and oil level, not bleeding oil from anywhere especially the rear bell housing area), it sounds like some kind of galley issue. May be the machine shop forgot to put in the front galley plug. Without the front plug, the oil would just flow towards the front of the engine and dump itself into the govenor gear/cam shaft gear/crank shaft area without building up much pressure (no resistance) Then run back into the oil pan. Unfortunately the plug is behind the cam shaft gear and not easy to see (I do not remember if you can see it when the cam is turned). Eitherway this basically means taking a significant amount of the engine apart. Thinking out loud, do you have a way to pump oil? If it is missing the front plug, I wonder if you drop the oil pan, remove the oil pump and pump oil manually through the galley direct the hose toward the front of the engine, will it flood out the front of the engine? If you pump oil in from the pressure gauge port (without removing pump or turning the engine) will oil flow out the front of the engine? If the rear plug was missing, there would be oil coming out of the bell housing area. When the problem is found, please let me know what it was.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
