Re: i'm stumped 2
Posted by Brownie450 on July 05, 2007 at 16:52:39 from (207.177.82.61):
In Reply to: i'm stumped 2 posted by james in mo on July 05, 2007 at 09:53:43:
Is the coil primary connected properly? AS in a positive ground system would have the + terminal connected to the distributor "hot" connection. May make a difference. Try pulling at wires which feed the coil from the ignition switch down to the distributor. There may have been a terminal connection which got overheated when the switch was left on. This is not likely, but you need to check all primary wiring. Our SMTA had the coil primary feed wire break inside the insulation where it goes over the valve cover. Check it all out.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
