Re: May have H gear noise figured out
Posted by Bob Kerr on July 05, 2007 at 18:45:19 from (205.188.116.73):
In Reply to: Re: May have H gear noise figured out posted by LinemanFarmer on July 05, 2007 at 18:40:45:
I think it is common. I was told by a guy who lives down the road (who worked for an IH dealer 40 years ago) they were putting in the front trans bearings a lot even back then. Might be a good idea to check your M while it is apart, by the way, how is that going?
