Re: Farmall M Seat Shock
Posted by Andy Motteberg on July 05, 2007 at 18:46:13 from (4.143.222.170):
In Reply to: Farmall M Seat Shock posted by Clarkbug on July 05, 2007 at 11:51:49:
You can get a shock on eBay for $30.00 with the rubber bushings for the shock included. If you need the other rubber washers, they are on eBay for around $7.00.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
