Re: Farmall M clutch replacement
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by STMTS on February 09, 2000 at 11:39:21 from (206.181.23.74):
In Reply to: Farmall M clutch replacement posted by C.Fitz on February 09, 2000 at 11:31:51:
YES you can, you have to drop the hyd.pump if equipped.Then there is a big hole to work in, the bolts that hold the throw out bearing carrier are the only trouble,but are not that bad.You can't take out the flywheel though.I also work a Case and am working on a H right now a home.
Post A Followup
: Re: Re: Farmall M clutch replacement
