Re: M Gear oil and such
Posted by Bob Kerr on July 05, 2007 at 20:47:21 from (205.188.116.73):
In Reply to: Re: M Gear oil and such posted by Bob Kerr on July 05, 2007 at 20:38:11:
I better add this, RTV will not work as an axle seal, it will work for sealing the end cap and the top plate. I bet the axel seal is leaking beacuse the bearings are bad, that is usually the cause anyway.
