Re: 560 motor swap
Posted by Owen Aaland on July 06, 2007 at 01:42:25 from (65.165.246.40):
In Reply to: 560 motor swap posted by LittleMackinawFarmall on July 05, 2007 at 21:16:06:
The tractor needs to be split and then the engine can be lifted off the frame rails. The rear plate is between the side frames and the clutch housing and you have to remove the flywheel to get it off the block.
