Re: May have H gear noise figured out
Posted by NDS on July 06, 2007 at 05:54:30 from (205.188.116.73):
In Reply to: May have H gear noise figured out posted by Bob Kerr on July 05, 2007 at 18:22:58:
My Super M had slight noise when running in neutral but since everything else in transmission seemed OK I just ignored it. Went out one cold morning and started tractor and all kind of popping, knocking and grinding started, found out balls had came out of input shaft pilot bearing and cold thick oil picked them up carried them into gears and trashed the transmission. Quess the moral of this storyis a stich in time saves nine or however that old saying went.
