Re: super c hydraulic problems
Posted by the tractor vet on July 06, 2007 at 07:17:38 from (75.19.121.241):
In Reply to: super c hydraulic problems posted by farmall 66 on July 06, 2007 at 06:51:42:
You probably have the control valve sticking or the pressure relief valve sticking and it is not comming off high pressure when it reaches desired hight . With out getting into it myself and going thru everything it is hard to just say here is your problem . Ya may have a small burrs on the valve and it is not sliding free or a cut o/ring a tinny pice of dirt or lint from a rag . When one is working on hyd's you never wipe anything with a rag . Clean parts in a suitable solvent used compressed air to blow dry . Also having a good clean metal work surface and clean paper to lay parts on to let air dry . When getting ready to install blow that part off and dip in clean hyd. fluid and install. Also if you are like me and the old eyes don't see well anymore good lighting and a magnfing glass to inspect everything and dry hand fitting of all valves and spools is a must . Use crocus clothe to lightly polish valves and spools checking for burrs and scratches the best ya can on the out sides of valves and spools and in the bores them selfs.
