Re: IHC LA Engine Trouble HELP!!!!
Posted by Bob Kerr on July 06, 2007 at 07:54:45 from (64.12.117.8):
In Reply to: IHC LA Engine Trouble HELP!!!! posted by H fanatic on July 05, 2007 at 21:26:46:
I am not sure on the LA but on the M type when the engine is off, the throttle is open all the way. as the flywheel gets up to speed the throttle closes down. They are a throttle governed engine and not the hit and miss type although they look similar. If you get it started and are not sure about if you have the governor right, just get ready to yank the plug wire off incase it goes "runaway" on you. I would try to find a manual for it. It will show how to time it right. There are a few places that have them. Starbolt and hit amd miss enterprises are a couple I can think of right now.
