Re: super c hydraulic problems
Posted by georgeky on July 06, 2007 at 08:45:58 from (205.188.116.73):
In Reply to: Re: super c hydraulic problems posted by FARMALL 66 on July 06, 2007 at 08:29:27:
I think it is actually called a pressure regulator valve. It is in the lower hole of the unit after remaoving the cylinder head you can see it. There is also a relief valve, that goes under the unit. So it will have to be off the tractor to get to it. I would check the regulator valve and the orifice plug which is to the right of the regulator valve. It has a screen in it that may be plugged.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
