Re: IHC LA Engine Trouble HELP!!!!
Posted by H fanatic on July 06, 2007 at 09:12:00 from (152.163.100.197):
In Reply to: Re: IHC LA Engine Trouble HELP!!!! posted by KEB on July 06, 2007 at 08:03:33:
The Impulse clicks and seems to work as it should. I looked at my manual and it says to line up the timing marks on the magneto the one on the body and the one on the gear. But on the magneto where is the timing mark on the gear? What does it look like? Because there are three different marks on it. I found the one on the magneto body but not the one on the gear. I also can't even get it to putt when I use starting fluid or even if it put a little gas in the cylinder.
Nick
