Re: super c hydraulic problems
Posted by Cedric on July 07, 2007 at 04:14:02 from (210.54.85.14):
In Reply to: super c hydraulic problems posted by farmall 66 on July 06, 2007 at 06:51:42:
If the engine is under load with the levers in any position the problem lies with the pressure regulator valve.
Either the regulator valve piston and its seal ring are stuck in the block bore, or the orifice plug is stopped up with foreign matter, making the regulator inoperative. You will need to remove the regulator piston and orifice plug and check them out. The hole in the orifice plug is small and can easily be blocked.
The Blue Ribbon Serviceman's Handbook GSS-1024 is a handy book to have when working around these units. Sid.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
