Re: M won't start.
Posted by old on July 07, 2007 at 11:38:50 from (4.245.2.244):
In Reply to: M won't start. posted by 40 acres on July 07, 2007 at 10:46:15:
You say you check the plugs BUT did you check for spark. A lot of times if they get wet you can have water in the distubutor which will cause the points to corroade and also some time if the cap is old will short out the cap because of cracks in it that you can't see.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
