Re: cub VS cub lowboy
Posted by K-Mo on July 07, 2007 at 17:41:35 from (65.169.189.2):
In Reply to: cub VS cub lowboy posted by jk on July 07, 2007 at 17:09:13:
The Farmall Cub uses the 54A Blade which can be mounted belly or front.
The Lo-Boy uses the L-54 which is a front mount only.
IH Cub 54A & L-54 Leveling & Grader Blades Manual 1005880R1 DTD 2-3-61
K-Mo
