Re: 2400A (454) clutch
Posted by rret on July 08, 2007 at 04:04:59 from (24.151.127.169):
In Reply to: Re: 2400A (454) clutch posted by Janicholson on July 07, 2007 at 15:20:01:
while replacing the throwout bearing i figured i would replace the PP and clutch disk too. the clutch kit from hy-capacity had a chinese made pilot bearing which i decided not to use.
the tractor used to grind a little when going from Neutral to forward or reverse. now it is grind free. the new clutch really helps.
