Re: Clutch only jumpy in reverse
Posted by John-Paul T on July 08, 2007 at 11:45:26 from (216.169.177.76):
In Reply to: Clutch only jumpy in reverse posted by Jimer on July 08, 2007 at 10:39:29:
(take this as thought not what to do)
Im no tractor guro (here to learn myself)
But are you sure its the clutch? That should act same in all gears. I would suspect its the reverse gear or if its shuttle shift its something with that not the clutch. Either way I think you will have to take it apart to see andit maybe very obvious at that point (like tapered IE badly worn reverse gear)
I hope someone that knows more about this tractor will chime in with some advice for you. The above was just something to think over while checking the tractor out.
