Re: Tie Rod or Welded Cyl. for my Loader??
Posted by Janicholson on July 08, 2007 at 18:51:52 from (66.173.50.44):
In Reply to: Tie Rod or Welded Cyl. for my Loader?? posted by Wayne Rimathe on July 08, 2007 at 09:34:08:
If the Ram is the same diameter, and the cylinder is pressure rated the same or better, I would go with the least expensive. I have used tierod cylinders often. JimN
