Re: 400 Whats the Fix???
Posted by Bob M on July 09, 2007 at 06:34:11 from (151.190.254.108):
In Reply to: Re: 400 Whats the Fix??? posted by the tractor vet on July 09, 2007 at 05:57:33:
Tractor Vet - Indeed!
The bellcrank adjustment I describe is a "quick 'n dirty" method that's often sufficient to bring a fast idling H or M back under control. Incidentally if the other governor parts are OK it will generally result in a properly adjusted linkage when completed.
However if governor internals (bushings, spring ends, etc.) are badly worn, the work you describe is required to get the governor to working right.
