Re: More Binding Questions! Shocking, huh?
Posted by Sam#3 on July 09, 2007 at 06:35:19 from (12.214.113.46):
In Reply to: More Binding Questions! Shocking, huh? posted by Crazy Red Power - S.E.-Wi on July 08, 2007 at 22:27:33:
When I learned to shock we used ten bundles. Start by setting two side by side slightly leaning toward one another. Set two at a right angle to the first two. Use four to fill the corners. The cap is made by taking two more bundles breaking them across your arm and spreading them to make a cover for the top of the shock. Lay them at right angles to get good coverage. Once you start shocking you will find why you want the bundles tied in the middle (The operators job) and be sure you set the bundle firmly into the stubble.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
