Re: GREASE CAPACITY IN 140 STEERING HOUSING?
Posted by Hugh MacKay on July 09, 2007 at 14:03:38 from (209.226.106.100):
In Reply to: GREASE CAPACITY IN 140 STEERING HOUSING? posted by BIG RED 1 on July 09, 2007 at 12:44:28:
Red: Put the zerk in the drain hole and pump until grease comes out the top. I have gone over 3 tubes of grease.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
