Re: 3082 Backhoe
Posted by Armand Tatro on July 09, 2007 at 16:07:15 from (67.176.252.97):
In Reply to: 3082 Backhoe posted by Rick Jacobs on July 09, 2007 at 03:26:56:
Check your model number. I think you have a model 3820. Have you had one of the drive tires fall off yet? The lug bolts are threaded on each end with a flange in the middle. The inner nuts are inside the brake drums and you will never know if they are loose until wheel falls off. You have to take hub bearings apart to check inner nuts. Better check about this with your local mechanic and get all repair and parts books. Armand
