Re: Help on wiring of an M
Posted by Janicholson on July 09, 2007 at 16:41:45 from (66.173.50.173):
In Reply to: Help on wiring of an M posted by Mifsud on July 09, 2007 at 16:18:25:
Do not Use the resistor (I would take it off to reduce the clutter). Using it will result in bad spark. The neg wire goes to the distributor post with the nut and insulated washer (which connects to the points and condenser inside. (be sure to keep it insulated at the hole through the distributor.
JimN
