Re: Farmall M Brake Adjustment
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Tim W on February 09, 2000 at 19:03:05 from (207.246.76.128):
In Reply to: Farmall M Brake Adjustment posted by Lance on February 09, 2000 at 18:19:56:
Lance, There is a set screw on the bottom of the band cover.screw it in as til it stops, then back it off 1/2 a turn. Get the correctt petal movement distance with the threaded yoke. Be sure to get each side the same. Petals should have free movement of of 1". If that doesn't do it, take the cover off and check the bands for wear.
Post A Followup
: Re: Re: Farmall M Brake Adjustment
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
