Re: 656 hydraulic leak behind the lever by the seat
Posted by Allan In NE on July 10, 2007 at 04:11:45 from (148.78.243.25):
In Reply to: 656 hydraulic leak behind the lever by the seat posted by tim schlodder on July 09, 2007 at 22:18:23:
Tim,
Is it leaking out from around the hitch control lever or down at the remotes?
If it is at the hitch controls, the fastest, easiest way is to remove the seat, the square metal cover and then take out that reservoir standpipe to drop the oil level.
Will not affect operation in the least and will stop that weeping at the shaft. Don't know why IH thought that cavity had to always run "full to the brim" all the time anyway.
If the leak is at the remotes, sounds like some new o-rings are in order.
Allan
