Re: tractor vet-clutch adjustment mechanical TA
Posted by Owen Aaland on July 10, 2007 at 23:28:52 from (65.165.246.40):
In Reply to: Re: tractor vet-clutch adjustment mechanical TA posted by karl f on July 10, 2007 at 19:00:32:
All TAs can be tested the same for adjustment. This applies to both mechanical and hydraulic styles.
Make sure that you have two distinct speeds when the TA lever is shifted. Face the tractor uphill. With the transmission in low gear and the TA lever forward, make sure that the tractor will start roll backward when the clutch pedal is about 3/4 of the way depressed. With the clutch fully released, make sure the transmission can be shifted even when the tractor rolls backward a little. With the tractor in first gear, start to release the clutch. Let up a little on the brakes to find the point where the TA will lock up and the tractor stops rolling backward. From this point, you should need to release the clutch a little more before the tractor starts to move forward. If the tractor starts to move before the TA locks up you will get a double shift when releasing the clutch.
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
