Re: Bad noise in b.n.engine help??????????
Posted by Brownie450 on July 11, 2007 at 06:21:56 from (207.177.82.57):
In Reply to: Bad noise in b.n.engine help?????????? posted by COPPER KAT on July 10, 2007 at 21:43:55:
Have you checked for oiling in the valve/rocker arm area with the valve cover off? My brother overhauled his tractor,& the oil plugs in the ends of the rocker arm shaft had moved inwards & of course the oil would loose pressure. This was a 4010 jd, but it would pay to check into oil delivery & pressure right away. I believe an oil pressure plug or even such a thing as maybe the front cam bearing was left out at the shop.
