Re: Torque on Manifold bolts on H
Posted by Bob Kerr on July 11, 2007 at 19:50:25 from (152.163.100.197):
In Reply to: Torque on Manifold bolts on H posted by Tom Windsor on July 11, 2007 at 18:34:04:
I am not sure of the spec, but this may help, I torque mine like this. Lightly oil the threads and then I run the nuts on by hand till hand tight to hold it, then with the torque wrench tighten them up a half turn at a time until it is close to spec and then a quarter turn at a time. Start in the middle and work outward each go round. Even if the manifold is slightly warped it will allow time inbetween for the iron to flex a tiny bit and allows the gasket to evenly crush down. Don't forget to retorque it after it runs a while. and it is not a bad idea to retorque it again a week or so later when cold. If you do all that it will never come loose on you in the future. ( I do the same thing on cyl heads!)
Home
| Forums
Today's Featured Article -
Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
