Re: So I have this idea........
Posted by the Unforgiven on July 11, 2007 at 21:03:29 from (66.146.249.116):
In Reply to: So I have this idea........ posted by Patrick Martin on July 11, 2007 at 19:43:12:
I have a Farmand on an F20 with a pto pump. It has what looks like a regular small spine to standard adapter, but it is extra long. The drive on the pump is hollow, so you slide the pump on the pto and the excess sticks out the other side, so you can still hook a pto shaft to it. Has a bracket to stabilize the pump. The adapter and pump are probably standard Farmhand stuff. I have also considered skinning out an old TommyLift and making a 12V over hydraulic lift for an A.
