Re: So I have this idea........
Posted by Randy in NE on July 12, 2007 at 05:10:42 from (204.124.193.192):
In Reply to: So I have this idea........ posted by Patrick Martin on July 11, 2007 at 19:43:12:
If you put a priority valve on the side of your hydraulic unit this will do the trick, as long as you have a two way cylinder on the drag. The hydraulic unit holds less than one gallon so it doesn't have the capacity to handle a one way cylinder. Check Saginaw County tractor parts. I have a setup on one of my C's with a 2 1/2 gallon tank that I have connected into the suction side of the pump. We use it to raise the hoist on an old farm wagon. It isn't fast but it gets the job done. We only use this once a year when we dig potatoes.
