Re: So I have this idea........
Posted by Nat 2 on July 12, 2007 at 05:45:25 from (64.80.108.52):
In Reply to: So I have this idea........ posted by Patrick Martin on July 11, 2007 at 19:43:12:
Since the remote valves for the C/Super C/200 are kinda tough to find in my experience, why not use a bypass block on the factory hydraulics? There is a machinist selling them for very reasonable prices on Ebay right now.
You install the bypass block in between the hydraulic manifold and the touch control block, then run hoses to a readily-available open-center hydraulic remote valve. Add quick connects to the work ports on the valve, mount it somewhere convenient, and viola!
