Re: adding a fan belt pulley to a 400
Posted by SDE on July 12, 2007 at 20:17:19 from (207.118.223.218):
In Reply to: Re: adding a fan belt pulley to a 400 posted by Janicholson on July 11, 2007 at 17:03:39:
Thank you Jim. I drill and tap parts almost every day that require True Position to be with in .015 each. To get within that tolerance It usually must be within .005 of the bolt hole radius. My machine is old and tired but we can get it done. I will check the pulley over and see how concentric the I.D. is to the O.D. as well. Thanks again.
SDE
