Re: Does a wd have better Hyd than an M
Posted by georgeky on July 13, 2007 at 08:06:15 from (152.163.100.197):
In Reply to: Does a wd have better Hyd than an M posted by 80demoace on July 13, 2007 at 07:59:45:
With a 12 GPM live pump put on it. Depending on the year of the M one from a 400 or 450 will work. If you M is newer than mid 50 it should bolt right up.
