Re: Thermostat housing problem
Posted by Marty K on July 13, 2007 at 09:10:19 from (198.205.32.94):
In Reply to: Thermostat housing problem posted by Sonny G on July 12, 2007 at 14:06:58:
I took mine along with my manifold to an engine shop where they faced both surfaces of the lower thermostat housing half. Not sure yet if it's sealed because I am still in the restoration process and haven't refilled the coolant yet.
