Re: Does a wd have better Hyd than an M
Posted by Owen Aaland on July 13, 2007 at 14:29:55 from (65.165.246.40):
In Reply to: Does a wd have better Hyd than an M posted by 80demoace on July 13, 2007 at 07:59:45:
If you M is using the belly pump it is probably rated for 750 PSI. The AC could well have a 3000 PSI system on it. That is why ACs used such small hydraulic cylinders.
