Re: M - Oil Issues
Posted by D Slater on July 13, 2007 at 18:40:40 from (71.164.58.156):
In Reply to: Re: M - Oil Issues posted by Trouble on July 13, 2007 at 16:13:28:
On the long bolt that holds oil filter case on, There's a small orfice hole if it gets pluged it will keep oil from circulating. If thats not it, oil flow to filter is from near where oil pressure line port is so the problem would be in a close area to filter and I would unbolt base and look for problem.
