RINGS--which side is up
Posted by SDE on July 13, 2007 at 21:10:56 from (207.118.223.218):
When I removed the old rings I took notice of which side had the beveled edge. The beveled edge was up.
The new rings show that if they have a stamped dot on them, (they do) that side goes up. They also have a beveled edge, which if the dot goes up, the beveled egde goes down.
If they did not have the dot, the beveled edge is shown as being up.
Am I correct to assume that the dot is the determining factor and that I should disreguard the remaining info?
THank you
SDE
