Re: Mag problems
Posted by El Toro on July 14, 2007 at 03:40:03 from (205.188.116.73):
In Reply to: Mag problems posted by HENRY E NC on July 13, 2007 at 06:24:02:
Check the wiring where you connected the condenser and coil wire from the mag on your new points to make sure they're not grounding against the the mag. I would disconnect the mag grounding wire at the mag until you find the problem. If the tractor ran before I wouldn't buy a coil. You can always reinstall the old points and condenser to see there's fire. Look
at the rotor to where its pointing. Hal
