Re: 140 not running smoothly
Posted by old on July 14, 2007 at 14:14:02 from (4.245.3.181):
In Reply to: 140 not running smoothly posted by TxFarmer84 on July 14, 2007 at 13:52:06:
When you replced the cap did you take all the wires off and then put them back on or did you do it the right way and change one wire at a time??? If you took them all off then you have the firing order wrong and yep it will not run well if you did that. Common mistake made by a lot of people. Always when replaceing a cap take one wire at a time off never all of them
