Re: M and snow
Posted by Bob M on July 14, 2007 at 19:05:06 from (69.205.124.61):
In Reply to: M and snow posted by Carden on July 14, 2007 at 18:05:00:
Your idea will work fine. My Super M pushed snow (and occasionally also gravel and dirt...) for 30+ years using a plow frame bolted to the tractor side rails.
Just make sure the plow frame is substantial - mine was welded from 6" channel. Also that bolts into the tapped holes in the bolster casting, and thru the holes in the side rails as far back (as close to the transmission) as possible.
