Re: timing a H
Posted by CNKS on July 14, 2007 at 19:10:25 from (204.249.178.32):
In Reply to: timing a H posted by stevex on July 14, 2007 at 13:39:00:
Provided you did not remove the mag and it was in time before you messed with it:---Loosen the mag and put the top of the mag against the block. Pull the #1 plug, put your finger in the hole and hand crank until you feel compression. Then continue to crank until the marks are lined up. Then slowly pull the top of the mag away from the block until the mag trips. You are now in time. If not you have worn parts inside the mag. If you removed the mag and don't remember how it was set before removal, the procedure is the same, except that you turn the drive until the rotor points to the #1 terminal, install with the top of the mag against the block and pull out until it trips.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
