Re: m farmall with low oile pressure
Posted by Jason Simmerman on July 14, 2007 at 21:17:01 from (71.168.48.140):
In Reply to: m farmall with low oile pressure posted by Bob Tedford on July 14, 2007 at 19:27:22:
Sounds to me like you have bearing clearances out. Rod bearings are usually splash lubricated (I'm not sure on the Farmall M if it is or isn't) but in any event, the things that have the most effect on engine oil pressure is clearances in the pump, main bearings, and cam bearings. Might need a complete overhaul, but those are the things that can cause questionable oil pressure.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
