Re: Super C won't start?
Posted by ScottyHOMEy on July 15, 2007 at 07:21:29 from (70.105.246.111):
In Reply to: Re: Super C won't start? posted by Dan( Mass) on July 15, 2007 at 04:06:17:
My #1 is actually closer to 10 o'clock, meaning closer to the engine, but that doesn't mean yours is.
Best thing is to start from scratch. While you're turning the engine with the cap off, check to make sure the points are opening and closing properly. When you get the engine to the top of the firing stroke on #1, put your rotor button back on. Where it lines up is where your #1 wire will go. In case it's somehow got turned way out of time, you might try putting the cap on temporarily and mark the distributor body where the tower for #1 lines up, then remove the cap and make sure the rotor is pointing fairly close to that mark. If not loosen it up and turn the body until the mark lines up better with the rotor, then tighten ity back down beofre putting the rest of the wires on your cap and closing her up.
1-3-4-2, clockwise
