Re: Super C won't start?
Posted by El Toro on July 15, 2007 at 16:55:14 from (205.188.116.73):
In Reply to: Re: Super C won't start? posted by Dan(Mass) on July 15, 2007 at 15:26:03:
Don't worry about the points as long as they're set at .013". Bring No1 piston to TDC on the compression stroke and then see where the rotor is pointing. You need a helper, one to watch the screwdriver rise after you feel compression against your thumb and one to slowly hand crank the engine. Once the piston is at TDC ( its there when it quits rising) look to see where the rotor is and also the notch on the damper pulley should be at the pointer. If the notch is off you may have a sheared woodruff key on the cam gear. No1 piston and the notch (timing mark) are all related in an engine. Not only is your ignition related, but your valves too. If the key happens to shear it will throw off the valve timing too. Hal PS: Here's an IH distributor and No1 plug wire goes in the top right hole of the cap.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
